Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
MacBook won't switch on after swollen battery
Hi, I have an old (mid-2008) white macbook that has been going strong until now.
I noticed that the battery had swollen so removed it and tried to boot up just with the power cable but nothing happened. I ordered a replacement battery and it is charging fine but the macbook still won't boot.
It turns on briefly, I here some whirring inside, what sounds like the cd drive making a noise and the white led comes on for a few seconds, then a click and off it goes.
I've tried numerous reset options...holding cmd, option, P, R etc. and power button 30 secs but still nothing.
Is there anything else I can try or is it fried as I suspect?
Score 1
1 Comment
What happens if you try the original battery again?
by
Add a comment
Most Helpful Answer
Remove the battery and disconnect the mag-safe; press and hold the power button for 5 seconds. Put battery back in and connect mag-safe and see if it will power up.
Score 2
3 Comments:
I've tried this. It still just powers up very briefly then switches straight back off again.
by
What is the battery test button now showing?
by
It flashes green to say it's fully charged so no problem with the battery. The mag-safe light shows green too.
by
Add a comment
Some generations of the Macbook will not turn on without a battery. You may simply just need to put a new battery in.
1 Comment:
Just bought a new battery, still no joy.
by
Add a comment
I had the same issue before where I would hear the laptop turn on, battery is working, but no display. I took it too the apple store and the Genius Guy said that the display was disconnected, probably from when i was working on my laptop. My suggestion is to take it to the apple store and say that your macbook wont turn on.
Add a comment
Add your answer
DrOrb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,086
