Phone glitching and freezing
My LG Escape 2 doesnt stop glitching as if someone else is controlling it and it also freezes time to time and i dont know how to make it stop.
Score 2
Add a comment
1 Answer
i have the same phone . it helps if you restart it at least once a week and also install a cleaning app to clean up the memory and get rid of any unwanted files like the cache and turn off your WiFi and Bluetooth and other wireless functions as they drain your battery fast and can also really slow down your phone because they put a drain on its ram (random access memory) . the apps i use are Du battery saver for my battery and mobile optimizer to get rid of unwanted files and clear cache. i also have all my music and pictures and other files like PDF's on my micro SD card
4 Comments:
i hope this helps
by
I have the same phone to but it shut down and it will not turn on but it will change
by
PLEASE HELP ME WHAT DO I DO WITH THIS PHONE it will not turn on but it will charge
by
sorry it took me so long i am not online very often .there is likely more wrong with it then and i wish i could help . it might be time for a new phone . if it has suffered water damage you may be able to take the back off and try to remove the buttons and clean them. or try moving the sim-card and micro sd card around. i cant turn the volume up and my headphone jack is a little messed up aka static .
by
Add a comment
Add your answer
Hannah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 180
