Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 Questions View all
Why are there vertical color bars appearing in 1 section of my scree
Vizio TV recently removed from storage (was only in from May-July) powered on and had vertical white bars with color stripes in one section of the screen. Looks like something in particular came loose or went bad, but I took the back off and have no idea what I'm looking for. Any help appreciated!
Update (08/04/2017)
@crowbot Any chance you can see/point it out here?
Score 1
2 Comments
Sorry but it's usually within the LCD unit itself. It's the electronics that interfaces the raw elements of the LCD to the video card. Usually there are separate chips for different sections of the unit. It looks like one failed. My experience has been that once this happens, the LCD sub-assembly needs to be replaced.
by
@dcjeffreys double check something for us. Bring up an on-screen menu on your TV. Let us know if those lines run through that menu as well....
by
Add a comment
Chosen Solution
@dcjeffreys with multi-colored vertical lines and the presence of some active video is usually an indication that the video processor is not the cause for this. You may have issues with Source Tab Bond failure (thin ribbon cables going directly into the panel have come unglued) or a bad T-con board. Yes panel failure is always an option but I'd check the other two things first. Let us know what model your Vizio is. Try something. Push the top of the actual LCD panel where the lines start. See if you can find the thin ribbons going into the panel. If it is a TAB error, you should see some changes when you exert some pressure. Let us know what you get.
Score 2
2 Comments:
I bought 50 inch Vizio TV in june of 2121. Today is 1/31/22 monday.
On this past Saturday a vertical top to bottom white line that is 3 or 4 inches wide 3/4 to right of my screen appeared.
Bought at Walmart $330 .
My smart TV is wall mounted. Getting to the back for elderly with a broken hand is impossible.
I wish electonics were quaily built in the first place. ?
by
@Robin Shahan totally agree with you on that one but we all know that this is wishful thinking on our part. Anyhow, your TV should definitely still be covered under warranty, VIZIO provides a warranty to the original purchaser of a new Product against defects in materials and workmanship for a period of one year of non-commercial usage and ninety (90) days of commercial use. So don't let anybody tell you different. https://www.vizio.com/en/terms/warranty-... Give them a call and tell them you want this fixed. Do not take no for an answer.
by
Add a comment
Devon,
Sorry to tell you but this looks like a classic example of a failed video controller in the LCD module inside the display.
Check the cable going into the display module. Its usually a ribbon cable of some sort. Make sure it's in tight at both ends.
You can also try GENTLY squeezing the frame above and below the area of the bars. This may bring it back to normal temporarily.
You may be able to buy a replacement LCD module but it may not be cost effective.
Hope this helps.
-Larry
Add a comment
Add your answer
Devon Jeffreys will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 22
Past 30 Days: 123
All Time: 17,994
