Washer gets stuck mid cycle
My samsung vrt steam washer , front loading (3 ish years old) gets stuck in the middle of the cycle.
It happens on different cycles, and at different times in the cycle (though at 33 minutes, and at 1 minute seem to show more frequently)
Th washer makes a sound similar to when it is filling, but it is not filling with water
Powering off the washer seems to be the only way to unfreeze it, but the cycle does not complete
1 Comment
I have the same problem. Looking online it could be the Water Inlet Valve. Instead of turning off, mine has a pause button. I push that, then back on and it picks up where it left off.
by
Add a comment
Chosen Solution
Use a multimeter and check the door switch.
Score 1
Add a comment
https://www.youtube.com/watch?v=eVPg9AcW...
The Power invert board got heated which could send wrong signal or block the current to send a signal.
I have removed protective film from the board to release the heat. Solved
Add a comment
Add your answer
Dan Fashimpaur will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 32
Past 30 Days: 104
All Time: 7,478
