This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
What is the best (easy) way to fix the Bootloop issue?
My LG V10 got the dreaded bootloop issue. It would no longer power on or charge. There are many fixes on the internet but they are quite intricate and complex. Is there a straightforward method?
Update (08/03/2017)
How exactly do you apply heat? I only have a blow dryer...
2 Comments:
Take of the motherboard, apply heat around 100 degrees celcius and then apply some thermal paste on the black coloured chips and put it back... THIS IS A TEMPORARY SOLUTION. My suggestion is go to lgmobilerepair.com and send ur phone to the lg facility.. they'll repair it fror free no matter the warranty.
by
I suggest that you avoid doing this, as there is greater risk involved in reflowing PCBs on your own. You could make it even worse. Send it in as the previous person suggested.
by
Add a comment
1 Answer
The only method I've had luck with is to disassemble and reflow the problematic chip with heat. All the other tricks/tips you see are only temporary (or momentary) fixes.
Add a comment
Add your answer
Alina Dahl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,275
