Are there any Front Glass Replacement
My fornt glass is borken, looking for a Front Glass Replacement for iMac 27" 5K Late 2015. Apple told me I need buy a full screen for 700€, any solution?
Ouch! Sorry guy Apple uses a sealed on cover glass in the newer 'Thin Series' ;-{
A few people have tried but in the end they broke down and got a new display assembly instead.
The problems you face here is first even finding the glass which is quite thin and has a polished edge that is the correct size. Don't forget the original also has anti-reflective vapor coatings the glass you get most likely won't have them.
Then you'll need to cut carefully the seal between the LCD and the cover glass and not damage the LCD in the process! This is where most failed as the cover glass shard either damaged the screen or just the process of taking it apart killed it.
Sorry
Apple Part #:661-00200
iMac 27" LCD Panel and Glass Assembly, Late 2014 / Mid 2015
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 3,798
