vbat vs vccmain different//?
i want to know different between vccmain and vbat power rails. i know both same voltage. who create vccmain ? pm ic or q1403??
Q1403 is a power MOSFET (P-Channel enhancement mode MOSFET). This kind of FET is used for high-side switching, allowing PP_VCC_MAIN to charge the battery or not.
So in essence:
What's not entirely clear is what the battery lines in Tigris (A1-D1) do because we don't know what the internal logic is. Are they switched internally to output at VDD_MAIN (A2-D2) when no charging occurs or does BATT_VCC go though the body diode of the MOSFET to supply VCC_MAIN? Given that there is very little Forward Voltage drop measured across the body diode, I believe it is the former and not the latter. Only the Apple engineers know for sure.
EDIT
I've edited this answer so that it is a little clearer and more importantly, there is a big unknown because no one knows what the internal logic of TIGRIS is. This answer is my "reading" of the schematic. Only the Apple engineers know for certain what goes on inside TIGRIS.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 688
