washer sounds like it drains but motor never stops, you have to unplug
washer sounds like it drains but motor never stops, you have to unplug to make it stop. Then when you try to restart any cycle - the motor goes back to where it left off .” Doesn't start the spin cycle
Any suggestions?
3 Comments
@auntaa I am a bit confused by this. The motor never stops doing what? Pumping? Does it drain? What works on your washer? What have you checked?
by oldturkey03
Thanks - it drains but the pump does not stop and kick over to spin
by Ann B
@auntaa the pump "does not stop and kick over to spin" What do you mean by kicking over? You put the dirty laundry in, your washer fills up with water and washed, then it drains and does not stop draining???? What exact model is your washer?
by oldturkey03
