A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure.
120 Questions View all
My washing machine is not draining
I get a d5 code. Water is not draining.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
@dawndefreece, Dawn, If all other functions seem to work, make sure drain hose is not kinked, check plugs/wires for good connection/corrosion. Probable either washer has something clogging the pump/hose and preventing it from draining or defective drain pump. You will have to find a way to remove water/bail/wet shopvack, to do the next step. Remove hoses and pump and check for blockage, debri,etc. remove if found and try machine, if no blockage replace pump. link below will show removal of pump. Good luck.
https://www.youtube.com/watch?v=NOWZPmen...
Score 3
Add a comment
Add your answer
Dawn DeFreece will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 38
All Time: 414
