Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Proximity sensor doesn't work even after screen and flex replacement
Hello.
I'll try to tell you my "story" briefly.
1 month ago I went abroad and bought me a new iPhone 6s plus LCD.
came home, replaced the screen - The screen doesn't dim at all while calling...
I was thinking what went wrong... my proximity sensor DID work!
Fortunately I had a new proximity sensor flex cable (that also comes with front camera and all...) and replaced to that new flex cable - STILL NOT WORKING!
Tried to seek online for solutions and and I figured out that probably the screen was doing the problem and its a fault. But I can not go to the store and replace it because it was abroad, so I tried all the solutions online to fix the proximity sensor eyepiece in the screen.
Tried to scrap the color and recolor it with a black pen and do a little holes - STILL DID NOT WORK.
This time I gave up and went to buy a new screen, replaced it to the new screen - AND STILL DON'T WORK!!
After that I tried to do an hard reset and reset all settings - STILL DON'T WORK!
I don't know what to do... I am trying to see if the the proximity sensor bracket (the transparent little piece that holds that) doing the problem because he was painted a little bit in black while I was painting the screen eyepiece... maybe I will replace it?
What do you think I need to do?
Thank you
Add a comment
1 Answer
I'm not sure what your skill set is, but I have had this issue in the past after working on a phone and this video really helped. It is most likely not your actual sensor and is a component on the Mother (Logic) Board.
A skilled Micro Soldering repair shop could do this for you if you could not.
Hope this helps!
https://youtu.be/TOCyk6gTIy4
2 Comments:
Ok thank you, I'll check it...
It's my last hope :(
by
Let me know, hope it does :)
by
Add a comment
Add your answer
liorgolan29 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 287
