Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Works fine until it dies
I have an iPhone 6s and I've replaced 3 batteries so I know it's not that. The phone works fine when it's on, the battery charges fine , everything is perfect when the phone is on.
Then when the battery dies the phone won't turn on, the charging logo doesn't pop up the screen is completely black. Please help.
1 Comment
What kind of computer do you have it working with, Mac or PC?
by
Add a comment
1 Answer
Chosen Solution
Charging IC chip is bad on the logic board.
You will need to get it replaced by someone that does micro soldering.
Unfortunately it isn't a job that DIYers can do unless they have good experience in soldering including having the tools such as a microscope, rework station, soldering iron and more.
It's a partially bad charging IC which is why you see the battery does not get charged up when the battery is flat.
Usually the use of car chargers bundled with cheap / copy lightning cables cause the charging chip to get damaged over time.
Score 4
Add a comment
Add your answer
Jack Sargent will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 43
