Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
237 Questions View all
Is my phone still savable?
i had my phone in a bad to avoid water, the bad somehow got a hole in it and my phone was filled with water. It was off when i put it in, but when i took it out it had a white light on where the alerts come on, and was really hot. Is it still savable? i put it in rice and haven't turned it on
Add a comment
1 Answer
Chosen Solution
Cristian Perez the very first thing you want to do is to take it out of the rice. Rice does absolutely nothing to repair your phone. It only provides you with a false sense of security while corrosion will continue to destroy your phone.
Do not try to use your phone, do not try to plug it in, turn it on or anything else. Then use this guide to remove the battery and the motherboard. Once you have that accomplished, it is time to clean. Use this guide to clean it. It was written for an iPhone but all the steps are still pertinent to your phone as well. While you are cleaning your board and all connectors etc. check for any missing or burned component. Post some images of your board with your question. Use this guide for that so we can see what you see.
Once it is properly cleaned, replace the battery and only then reassemble your phone and restart. See what happens. Unless it is cleaned, you can not properly troubleshoot your phone. If you are unable to perform the tasks I would suggest you contact people that specialize in those type of repairs.
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
iFixit Image
Guide
Adding images to an existing question
Difficulty:
Very easy
2 - 5 minutes
Samsung Galaxy S6 Edge Motherboard Image
Guide
Samsung Galaxy S6 Edge Motherboard Replacement
Difficulty:
Difficult
40 minutes
Score 2
Add a comment
Add your answer
Cristian Perez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 49
