Latch won't open after installing new harddrive
I upgraded my harddrive and installed OS without a problem, but after putting the case back together, the latch won't open fully, meaning I need to use the spludger to gently pop it open. I had a similar problem when I had my RAM upgraded last year, but the guys at the shop where I had it done were able to fix it. I'd prefer to not have to go back there again.
Does anyone know how to fix this?
Score -1
1 Comment
thanks for your help guys.....not sure what the problem was but it worked itself out....I think it was just an alignment issue
by
Add a comment
Chosen Solution
Most likely is that the top case was improperly aligned improperly. It's impossible for us to tell over the internet. I would examine how it's binding and reseat the top case.
Score 2
Add a comment
Hi, it sounds like there may be a small screw lodged somewhere underneath or behind the push-button bar. I think you can remove that bar after you've removed the top cover. From there you can see if there is anything keeping that press bar from being fully depress.
1 Comment:
charles, I don't mean to be tacky but do you really think he's still having this problem after seven months?
by
Add a comment
Add your answer
stevehort will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,150
