Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Why Does my display go dark after 15-30 minutes?
When powering the iMac on after being turned off for awhile the computer boots normally but after 15 to 30 minutes the display goes dark and does not recover unless the iMac is unplugged for a while or if I put the iMac into sleep for a few seconds then wake it up the display recovers and quickly clicks off.
If I unplug the iMac and power it back immediately on the display will shut of as the computer boots.
When I hold a flashlight up to the display you are able to make out whats on the screen and do things as normal I tried moving mouse around as well as playing audio through the speakers.
I believe this is a problem with the inverter are there any other suspects?
Add a comment
1 Answer
Most Helpful Answer
Change out the inverter:
iMac Intel 20" EMC 2105 and 2118 Inverter Replacement
Score 2
Add a comment
Add your answer
Ethan Stiles will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 56
