How to repair or replace the bulb primer
Does anyone know how to repair or replace the squeezy bulb primer on my petrol McCulloch Gladiator 550 hedge trimmer? It has stopped working. If I squeeze and release it, petrol does not flow into the bulb, or at least, not nearly as fast as it used to. Does anyone know how it works? The bulb has two black tubes coming out of it. I suppose one goes to the petrol tank and the other goes to the carburetor. i think this tube is different from the petrol feed tube, because (at least at the tank end) this is clear plastic. I imagine that the arrangement is similar to that used on other McCulloch devices powered by small two stroke engines (chain saws, strimmers etc.). I suppose one tube must be blocked, or trapped, or something, but how does one get access to it to see what's wrong?
Thanks - Rowan
1 Comment
The primer bulb on my McCulloch MH555P hedge trimmer is perished and leaking, unable to use to start motor. There are no visible screws to remove and replace. Does anyone have a set of instructions for the removal and replacement of the primer bulb and fuel lines? Please send answers to donaldbritz@orangekipper.co.uk. Thank you
by Donald
