Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Questions View all
overheating 60 degrees idle and going up to 95 while browsing
my macbook gets way too hot!
idle it's on 60 degrees and when just basic browsing it goes up to 94 degrees celcius and down to 40 and back up, it's like a rollercoaster
note that i use a second screen attached to my macbook.
is it a simple fix by just replacing the termal paste? or is it more a hardware or software issue?
Add a comment
1 Answer
Most Helpful Answer
How about opening the bottom cover and clean out the fans and the heat sink fins using a can of can'ed air and a soft paint brush to start.
If your system is still running hot can you give us a screenshot of TG Pro window (full) so we can see whats cooking here.
You may only need a new fan, HD maybe having problems as well as your HD SATA cable.
Update (07/01/2017)
You gave me a good clue here as Chrome is hard on drives (over Safari)
Sorry you have the classic case of worn SATA cable ;-{
What happens is the dialog between the CPU & SSD (in this case as you swapped out your HD) is breaking down. So when the CRC fails to match the block of data needs to be resent.
The best way to describe this is when you are trying to talk with a slightly deaf person and he is just getting every other word so he asks you to repeat, and repeat... At some point he manages to get what you said. But you do get hot under the collar after repeating it so many times! Thats whats happening here just bi-directionally!
You'll need to replace the cable here's the IFIXIT guide to follow: MacBook Pro 13" Unibody Late 2011 Hard Drive Cable Replacement As for the part you'll want this one: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable - Apple P/N 923-0104 and yes I know this is the 2012 version which is a better part.
I should point out you'll want to backup your data and reformat your drive. Often when we see this problem the drive can be mis-written so you'll want to clean it off and install a fresh copy of the OS.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Image
Product
$34.99
Score 1
1 Comment:
Bottom is all clean, not a single bit of dust there!
Installed a new 512GB SSD
I've discovered when I used safari it says around 60/70
but with Firefox, chrome,opera when I'm just even looking at the cryptocurrency graph the temp goes op to 95
i will do that later, thanks. give me a couple of hours
by
Add a comment
Add your answer
petergk will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 281
