Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Help me find power pads on my white unibody 2009 MacBook
This is the abridged version. This was my first time opening up the mac so I didn't know that you could replace the HDD without having to open the whole *!&$!&$^ thing.
Anyways, I replaced Its HDD to SSD and initially it worked fine, but a day later, it stopped detecting the keypad/trackpad and a day after that even the power button stopped working. I need to determine if this is a problem with the keypad connector or something since this was my first time opening the mac or if the logic board is dead.
Also, Since I don't have a usb to sata connector, I had to plug in the old HDD a couple of times to copy the data. And I directly upgraded from show leopard to El Capitan on the ssd. Is it possible that this was too much to take for the logic board?
I have a 2009 white unibody core 2 duo MacBook (identifier 5,2) 2.1ghz and a removable battery.
Here's how it looks on the inside: http://imgur.com/a/XcPzH http://imgur.com/a/Q2GBY
I am pretty desperate. At this point I will swim to Alaska naked if it helps to solve this problem. Help
2 Comments
You appear to have one of the first MacBook's (Mid 2006 to 2008) looking at the images. The memory modules on the first two generation MacBooks where side by side like your images. The 2009 series had a stacked setup one on top of the other.
- MacBook 13" 2.0 GHz Core 2 Duo (White/06)
- MacBook 13" 2.1 GHz Core 2 Duo (White/08)
by
The 820-2496 logicboard links to a Apple MacBook 13.3" A1181 MC240LL/A Early 2009 Series only
by
Add a comment
Chosen Solution
abhiminhas the power-on pads are located right next to touchpad connector. They are labelled as R5016
Score 5
1 Comment:
I just got it. Thank you so, so much. You're a lifesaver.
by
Add a comment
The power pads are just to the left of the keyboard and mouse connector, there should also be a small power logo next to it.
1 Comment:
IT WORKED. I can't thank you enough. Thanks a ton.
by
Add a comment
abhiminhas - The first gen systems only had a SATA I (1.5 Gb/s) HD port. So you should double check your SSD if it supports this slower speed. Most today are either fixed SATA III (6.0 Gb/s) or if they support multiple speeds only offer SATA II (3.0 Gb/s) & SATA III (6.0 Gb/s) support. The Samsung 850 EVO was one of the exceptions as it offers support for all three SATA speeds.
You might want to double check what you have for your system (see links above) and your SSD spec sheet.
Add a comment
Add your answer
abhiminhas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 706
