Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Having problems installing OS El Capitan
Bought a Toshiba MQ01ABD100 Media drive from iFixit for my mid-2009 MacBook Pro 13" (It is the exact same model that my local MacStore installed a couple years ago.)
Using various how-to's around the internet (since the iFixit how-to is for an older OS X),
I successfully made a bootable USB drive and booted off it. Got so far as erasing the drive using Disk Utility, but when I hit 'Erase" I get the following; "Erase process has failed..." Show Details reveals: "Wiping volume data to prevent future accidental probing failed. Operation failed..." Ran First Aid, everything copacetic. Tried again, same messages.
So I guess my question is: now what?
1 Comment
Add a comment
1 Answer
Chosen Solution
Ah! You likely need a new HD SATA cable! This series tends to have a high failure.
Here's the IFIXIT guide you'll need to follow: MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement and this is the part you'll want: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable - Apple P/N 923-0104. And yes, you want the newer part!
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Image
Product
$34.99
Score 1
Add a comment
Add your answer
Robert Pillers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 382
