Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
White Screen on startup, no Apple logo
So, I changed the Display on my Girlfriends Macbook and now when I try to boot it, it just starts with the chime and goes to a white screen and no Apple logo.
I used one of the guides from ifixit and followed it to the T. So I'm not sure what went wrong or what I did. I have tried the ram reset and every other thing I could find on the internet but nothing works. Just boots to a white screen.
Add a comment
1 Answer
Chosen Solution
I white screen usually indicates a hard drive issue. On some models a hard drive cable issue also. Did you replace the screen for this issue? What is the model number and do you know the year?
UPDATE
MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
https://www.walmart.com/ip/StarTech.com-...
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Image
Product
$34.99
Score 1
7 Comments:
No I didnt replace the screen for this issue, girlfriend stepped on it and broke the display. The LCD was fine I had just replaced the front glass. Model is A1278 and its mid-2012
I tried disconnecting the hard drive and booting from USB media but its still the same white screen.
For the record, it still worked before I replaced the display.
by
This is the exact model that has the hard drive/Ir cable issue. Apple was replacing this for free for the last 6n months but I've heard they have discontinued the program. The cable gets damaged on the bottom where the hard drive sits on it and on the top step. If allowed to go on for a while it destroys the hard drive. Remove the drive and hook it up via an SATA to USB adapter and see if it boots normally.
by
Okay, Sata to USB to my desktop?
by
Is there also a specific Sata cable that I need?
by
I have the same problem all white screen, ...I disconnected the LCD cable from the back of the motherboard and connected an external monitor on the external monitor port and was able to get Apple logo and login page. I hate concluding its the motherboard.
by
Show 2 more comments
Add a comment
Add your answer
Alex Plattsmier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,007
