Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
iPhone 7 freezing after screen repair
Hi, i work at a phone repair shop and i constantly have iPhone 7s that come back with a problem where they will be using the device and randomly the screen will freeze and they will have to shut it off and turn it back on. It only starts happing after the repair. was curious if this is a known problem and if it could be a repair oversight or faulty parts?
Score 4
Add a comment
Most Helpful Answer
I have brought this to the attention of many parts suppliers and this link will give you everything you need to know. This is why apple has a calibration machine, The iPhone 7 through 8 plus will experience this due to 4 separate manufactures of screens, LG, Toshiba, Sharp, and JDI. If your screen does not match that it will need to be calibrated with the machine or it will not communicate properly. Best solution is to check the first 3 characters on the screen and try and find one that matches the original.
'''https://webuylcds.co.uk/2018/05/15/to...
Score 3
1 Comment:
Or use eprom reprogrammer for 50$
by
Add a comment
Restart your iPhone 7(press and hold power button and volume down untill you see the Apple logo),if this still not work, backup your iPhone and do a factory reset.
Score 1
1 Comment:
It worked. Thank you.
by
Add a comment
Sounds like a screen quality issue. Have you tried different screens?
Add a comment
i also work at repair shop and having same issue , dont know what is it yet ................
annoying thing is customer are having problems because of my service :(
Add a comment
If each time it's the same thing, it's due to bad quality LCD. Buy a new lot of LCD.
Add a comment
My screen is on, but it doesn't respond when you tap, slide, or try other gestures. Wont even let me slide the power button off nor let me enter my passcode. Could i just need a whole new screen?
1 Comment:
You need new screen
by
Add a comment
Please don’t read comments from others… EPROM reprogramming needed. This is the only real and working solution. Costs 50$
https://www.youtube.com/watch?v=Uv4BDpWf...
Add a comment
Add your answer
Arima will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,807
