Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
553 Questions View all
Was running fine then no start
I have a crafstman riding mower,was working fine ,went to put away for the night and it won't start,. This is where it gets wierd ,key wont start it,will only start if I jump silanoid and then will only run on full choke, will die if I try to take off of full choke or engage blades. And it dies as soon as I release the brake/clutch pedal. Any help would be great.
Add a comment
1 Answer
Chosen Solution
@shane71 "key wont start it,will only start if I jump silanoid" and "dies as soon as I release the brake/clutch pedal." would be typical for a bad safety switch. I'd start with that. If you can tell us what model your mower is and what engine (model number) it has, we should find more information for you.
Score 2
2 Comments:
But the safety switch is working otherwise it wouldn't start at all its a model 1102o8a001116 with a kohear engine
by
@shane71 I based that on this ""key wont start it,will only start if I jump silanoid"" Buy starting it at the solenoid you are essentially hot wiring your mower and bypassing those safety switches. BTW your mower most likely has a few of those. Double check your model number please.
by
Add a comment
Add your answer
Shane will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 400
