Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 is stuck in Boot Loop
I have an iPhone 6 that is in a boot loop. iTunes will not recognize it when plugged in. Also it will not go into recovery mode or DFU mode as the loop cuts out before either are reached. I have had the phone charging for a total of about 5 hours. Dont care about saving data just looking to get working
I have also tried using dr.fone and ReiBoot with now luck because neither recognize that a phone is plugged in.
Score 1
Add a comment
1 Answer
Chosen Solution
A boot-looping device can be caused by many things.
Try these things (if you haven't already) to see if anything helps:
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Check the condition of all the flexes (with magnification)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Otherwise, you may have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop to do the troubleshooting. A shop that also does micro-soldering can go deeper if the problem is not modular in nature.
Score 3
2 Comments:
Hard reset, DFU, and Recovery mode did not work as it loops too fast. I have tried two computers. Tried a tool to put it into recovery mode. Tried disconnecting the camera ribbon and entire screen but not have not had any luck.
by
In that case, you likely have a logic board issue. Has anything happened to the phone prior to this issue (drop, bend, water etc)? Has it had a long history of minor drops?
I believe you will need to have this looked at by a repair shop that does micro-soldering repairs.
by
Add a comment
Add your answer
Jason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 7,189
