Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
White vertical lines at top of screen
Just replace battery I purchased from you all. After watching video on how to replace got it back together but now have a row of vertical white lines about a 1/4 inch tall at the top of the screen. Lines were not there before replacing battery. Is there something I can do to fix or something that I might not have done right on the reinstall? Thanks for any suggestions
Score 1
Add a comment
1 Answer
Chosen Solution
Either the LCD ribbon cable got damaged from the screen or it's not connected properly to the logic board.
You could try flattening the LCD ribbon flex cable if it's folded (Though I don't suggest this as only one iFixit user here managed to fix the issue doing that).
If none of these fix it then you will need to replace the screen to fix it.
Score 2
Add a comment
Add your answer
Clint Sharp will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,351
