Why is my phone stuck in headphone mode?
My phone is saying my headphones are plugged in even when I take them out? Its muting my calls i have to put on speaker mode to talk. Maybe this is a problem with my headphone jack?
Hey there,
You may have something in your aux port causing it to believe headphones are plugged in. Try to clean it out carefully with an appropriate tool. If it looks clean have the charge port replaced. That would definitely solve your problem. If you do it yourself just be careful because the LCD can easily break if you don't separate your screen properly. (Use a lot of heat)
Best of luck
The earphone / headphone jack is attached to the midframe assembly of the phone. It is not part of the charging port assembly.
SKU: 11-BK-1617
My mistake, the s5 has its own component but it is actually a little easier to swap. That is the piece you would need for replacement. Thanks.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,225
