Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 Questions View all
boys your help is necessary
I am fond of an Adobe Photoshop CC 2017, I edit photos and other, and I spend on it almost all the free time. But there was a trouble, to me the blue screen has come, and it was necessary to bear the computer on repair. I was upset a lot, when I learned that not all data could restore, and that data, which was returned… the most part, they have ceased to open. Almost all processed images, have gone up the spout. And now I need to recovery adobe photoshop.
Add a comment
Chosen Solution
I don’t know many effective solutions for damaged .psd files. But I still remember one effective program, it is called https://onlinefile.repair/en/photoshop.h... its advantage above others is in algorithm
See following https://helpx.adobe.com/photoshop/kb/bas...
Add a comment
Most Helpful Answer
It sounds like your data is corrupt and is probably ruined.
I would take it to a data recovery specialist, but they can be expensive.
But just look up "data recovery services near me" on google and call a few and compare their rates.
Find one with a fair rate and go to them and see if they can help you out.
Score 3
Add a comment
It's not Photoshop you're recovering from, as Photoshop is just software for editing photos. Your hard drive crashed. As Cameron said, a data recovery service may be able to recover your files, but they are often expensive. Next time, remember to make a backup. For that, put an HDD in an external case and make a backup often. That or a cloud storage program, such as google Photos. Google photos will back up any photos under 16MP for free.
Hope this helps!
Score 2
Add a comment
First, don't save anything to the hard drive with the photo data as it might overwrite the data. You can try some free data recovery software to see if you can recover files. It might be that the file table is corrupted with the actual data being ok. If you have two hard drives or partitions then save the recovery software on the one that does not have your data. https://www.easeus.com/data-recovery/dat...
Add a comment
Add your answer
Tonya Moore will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 153
