Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1366 Questions View all
Rear camera work only on timelapese, and Slow motion.
I've just got an iPhone 7 Plus from my customer as he report the rear camera is not working only black screen. After I test it It work only on right side camera so I check the left camera it's not working but flashlight is ok. First thing is do is reset all setting still not working. Second is restore it to IOS 10.3.2 still not working. I tried to replace another new camera already try 3 cameras still not working. Then I check components relate to left camera connector nothing is missing or not working still no clue. Then I replace U3001 still not working.
Can anyone help me to fix this problem?
Score 1
1 Comment:
How did you checked both rear cams ?
by
Add a comment
I did a little looking around because I'm having the same issue. All of what I read leads me to believe that it is an Apple defect (manufacturing defect)
So I would tell them to take it back to them.
Add a comment
You found the solution? Same problem here!
1 Comment:
i also had the same problem , heat the camera with hair dryer and the flex as well for around 20-30 seconds . it worked for me
by
Add a comment
Add a comment
Add your answer
Sengtay will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 38
All Time: 6,680
