Why my battery or nicads always drain fast
why my battery always drains so fast than i expected. does camera has a shorted wiring or need a repair
The First and most common procedure for Re-Conditioning a NiCd cell is by using a Technique
called "VOLTAGE SURGING". Over time the crystals within a NiCd cell begin to combine and get
larger. This causes them to loose capacitance and also break through the inner seals of the cell.
Surging the NiCd cell using a higher voltage causes the crystals within the NiCd cell to shatter and
become smaller. These smaller crystals have a greater surface area and therefore contain a greater
capacitance for energy. Crystals primarily grow larger during "OVER CHARGING". Over Charging
is the enemy of a NiCd Cells so Remember to leave your batteries on the charger for only the
minimum charging time OR LESS! This is usually an hour or less for Rapid Chargers or 2 to 4 hrs
for standard chargers. It is also best to only charge your batteries immediately before you use them.
Storing your batteries with a full charge encourages crystal growth. Storing your batteries on a low
charge , but not dead, is best. To keep crystal growth under control, you must also perform the
surge process below once every 3 months to keep you NiCd battery at its peak. Follow these
maintenance techniques to insure years of dependable use. http://ysuusy.com/easybatteryfix.html
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,110
