Can the ISclack be used effectively to remove a cracked MacBook cover
Can the ISclack be used effectively to remove a cracked cover glass from the MacBook laptops? I know the adhesive needs to be heated with an iOpener, but when that is done, it would be useful to have two suction cups and some leverage, and it looks like the ISclack might be useful...
Add a comment
Chosen Solution
Watch the video that's down a bit here:
iSclack
Personally I have bever used this tool when removing a MacBook glass. IMHO it is really to small to be of a lot of use doing this repair. It could be of some. It's just not going to give you that much suction.
You would probably be happier with one of these:
Heavy-Duty Suction Cups (Pair)
Heavy-Duty Suction Cups (Pair) Image
Product
$14.95
iSclack Image
Product
iSclack
$24.99
Score 2
Add a comment
You can, although seeing how big the glass is, you might break it. Specially if it is not all hot (hot, not warm) which is a pain for such a big glass and such a big aluminum frame that will be dissipating the heat.
My method is to tear through the adhesive using a plastic tool such as a guitar pick, horizontally and parallel to the frame and glass.
EDIT: if you are going to use the iOpener, heat one side, cut through; heat the next side, cut through while still hot, until you have done all 4 sides.
Must use that plastic tool ONLY as described above, as a cutting tool (be careful around the FaceTime camera), and NEVER to lift the glass even slightly. This will cause it to break.
Once the adhesive seal is broken all around, you can manually lift the frame, ideally by using suction cup.
Score 2
4 Comments:
Agreed, I just posted a minute behind you ;-)
by
2 minutes behind :)
by
I have had success in wrapping the display in a heating pad, then wrapping that in a towel; this allows very hot temperatures to be reached. Most of us cannot hold a metal object that is 140 degrees F or hotter, so that can be your "thermometer". Don't leave this setup attended lest it set your house on fire!
Since it is difficult to use a suction cup on shattered glass, I have had some luck with using a metal nail file to tear through the adhesive like Rany says; file down the big end of the nail file to be a wedge, and use the pointy end as the handle. IFixit needs to offer this type of tool...
by
Depending on the area the OP is, it might turn out pretty useful to leave the entire screen assembly under the sun for some time. Done that yesterday with a broken 13" Pro glass and managed to get all the glass removed with a guitar pick before it managed to cool down ;)
by
Add a comment
Add your answer
jimbreese will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 85
