Information and repair guide for the Kenmore Refrigerator 253.6481*40*, a top freezer model with an automatic defrost system and an anti-sweat heater switch, first introduced in 2004. This page covers information for model numbers matching the pattern 253.6481*40*.
Why is the there water leaking inside of the refrigerator?
Leaking water into my refrigerator
1 Comment
Does your refrigerator have an ice maker?
by
Add a comment
1 Answer
Most Helpful Answer
Cause 1
Clogged or Freezing Defrost Drain
If the defrost drain is frozen, the water will overflow the drain trough and drip down to the bottom of the compartment. This water can eventually leak onto the floor. Check the defrost drain to determine if it is clogged or frozen. If the defrost drain is frozen, thaw the ice. In addition, flush the drain with hot water to ensure that it is clear of debris.
Cause 2
Water Tank Assembly
Inspect the water tank assembly for any leaks. Be aware that the leak may be very small and hard to find. If you discover a leak, replace the water tank. Do not attempt to repair the water tank—glue will not stick properly to the plastic of the tank.
Cause 3
Water Inlet Valve
The water inlet valve opens to supply water to the dispenser and icemaker. If the water inlet valve is cracked or has a loose fitting, water will leak from the valve. Inspect the water inlet valve for cracks, and make sure that it is tightly secured to the water supply line.
Score 1
Add a comment
Add your answer
Christopher Flaherty will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 3,746
