Repair guides for the MacBook.
3787 Questions View all
DVD Drive No longer works
The drive will accept dvd and cd but just spins them for a bit and spits them out. I am out of warranty so is there an easy way for me to fix it and if not how much will Apple charge me to fix it?
Thanks In Advance
Score 1
Add a comment
Chosen Solution
It's time to replace the drive. Apple would charge about $30-$60 an hour but it's an easy DIY.
Score -1
1 Comment:
Apple does not charge for labor "by the hour". They use tiered flat rates for labor. This type of repair is considered Tier2, which means labor will be about $150, plus the part.
by
Add a comment
Most Helpful Answer
Yup, your optical drive is defective. If you are feeling adventurous I would say it's an easy DIY replacement.
From the ifixit website I have found the part you need:
MacBook 8x SuperDrive
And the ifixit take apart guide (assuming you have a Macbook Core 2 Duo):
Installing MacBook Core 2 Duo Optical Drive Cable
If DIY isn't your thing then I would (in my opinion) not take it to an Apple store because they do charge a premium for labor and repair. But they are usually the most reliable. So if money is not really a problem, go for the Apple store. But I would search around for an Apple Authorized Service Provider to see if they can do it for less.
Good luck!
Score 2
Add a comment
Sometimes the optical drive is still functional but needs a clean up to do efficiently his job. When there's dust (or if you smoke, tabaco fume residue) on the laser lens the laser beam may not correctly read the disk and the result is that the optical drive will spit it out. So if your intention is to replace the optical drive yourself you could open the optical drive (4 screws) and clean the laser lens with a Qtip and alcool (apply a very small amount of alcool on the Qtip and clean the lens without applying too much pressure on it then dry the lens with the other Qtip end). It's also a good occasion to clean the optical drive mecanism with compressed air and check if the black textile protection at the entrance of the drive is well glued in place.
Score 1
Add a comment
thank you guys i'm going to call apple and find out exactly how much it will cost. I'll also read up on the DIY
1 Comment:
Did they ever tell you how much it might cost? I just called and they refused to give me any type of estimate for the same problem.
by
Add a comment
If you don't want to replace the drive yourself, compare Apple's price with iResQ.com. I've had good luck with them in the past. Looks like they want $298 for a MacBook Superdrive replacement, ouch, though that includes shipping back to you.
Add a comment
is Collenthompson really David Icke?
Update (03/13/2019)
I’m just kidding Colleenthompson, no offence intended of course…
Add a comment
Add your answer
bob616 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 8
All Time: 11,664
