The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Keyboard replacement and battery
Hello,
I would like to replace the keyboard of my german MacBook Pro Retina 13" Early 2015.
But as I noticed from the guides in iFixit and other sources, I should disassemble most of the notebook in order to reach deep into the keyboard.
My question: should I disassemble the battery as well? Or can I leave it in place? Also should I disassemble the Force Trackpad?
Thanks a lot!
Score 2
Add a comment
1 Answer
Most Helpful Answer
Unless you are a skilled technician I would advise not attempting this procedure. I have done this repair on a water damaged machine I believe that I did remove battery to completely get to the keyboard: MacBook Pro 13" Retina Display Early 2015 Upper Case Replacement
The English-German skin I recommended in your previous question should be given a try first in my opinion.
That keyboard uses pegs for the most part. Here's is video on it being replaced if you decide to go ahead with it.: https://www.youtube.com/watch?v=e96zY4c6...
Score 4
4 Comments:
Can confirm you need to remove the battery and trackpad plate to replace the keyboard (covers bottom); you don't need to remove the actual trackpad
by
No, the trackpad does not need to be pulled.
by
I have the same issue, I have a MacBook pro 13' retina 2015, and some keys aren't working well. I would like to know if I need to take off the battery, to replace the keyboard. Thanks
by
Yes, the battery overlaps the keyboard.
by
Add a comment
Add your answer
halhouly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,873
