Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
iPhone 5 Wireless Charging?
Hello Everyone, I found an idea about wireless charging. I Want to attach built in wireless pad into my iphone but i have some problems about it. First of all pinouts, Which pins i have to use it on lighting charge flex ? Secondly, What happens if i want to charge with cable ? Thirdly,is it overheat my phone ? Thanks for replies.
PS: It was working on 30 pin iPhone 4s.
Add a comment
1 Answer
Most Helpful Answer
@naokotakeuchi, Hakan Er, Just a thought, you may best to contact the maker of the built in wireless pad to confirm if it can be used in the iPhone 5 and see if they have schematic/install instruction. Below are a couple links for you to check out to enable wireless charging of iPhone 5. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.macworld.co.uk/how-to/iphone/...
http://www.todaysiphone.com/2013/12/wire...
Score 2
2 Comments:
This links are all External Wireless Chargers, I need to do it internal. Soldering wireless charger to lightning port. Thats what i want. Example; https://www.youtube.com/watch?v=i7WDQz6v...
by
Hakan Er, That is a very cool charging system modification, sorry could not help more. The question will remain open for other volunteers to give there answers also if able. Good luck on your iPhone 5 mod.
by
Add a comment
Add your answer
Hakan Er will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 199
