Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
iPhone 5s completely dead, not charging, nothing!
My iphone one day suddenly turned off. At start when I tried to charge it then phone turned on, showed apple logo and then turned off and then these steps just repeated (turn on>show apple logo>turn off>repeat).
I tried to connect it to itunes but it was not being detected. Only when you connect it to wall outlet it turned on and did previous steps. So I searched on internet and found DFU mode so I did that.
Now my phone is completely turned off, no matter I insert charger or not. It just stay turned off and blank.
When I connect it with itunes, itunes says "found iphone in restore mode" (although phone is dead and blank) so I click on restore and as soon as it says "preparing to install" after extracting, it gives me an "error 2005" and stops..... I don't know what I do? Any help guys??!
Add a comment
1 Answer
Chosen Solution
Either battery is gone or a bad U2 Tristar charging IC.
When you plug it in and shows apple logo does the apple logo go off immediately after unplugging the cable?
If it does not then the battery is fine and it is probably the charging IC. Worst case scenario is that it may be the memory chip on the board needing to be reballed / reprogrammed / replaced. At that point I wouldn't consider it worth fixing.
Find someone that does micro soldering on iPhones and replaces charging ICs.
Score 2
3 Comments:
No, it doesn't turn on now. No matter what I do. The only thing it does is that when I connect it with itunes then i tunes detect it and says iphone detected in recovery mode and tries to restore but gives an error 2005 during installation after extracting. iPhone stays off all the time no matter you insert it in wall charger or in USB port of computer!
by
Ah, it's stuck in DFU mode after a failed iTunes restore attempt.
Try holding home + power button to hard shut off phone and get the apple logo to turn on and unplug cable quickly to see if apple logo goes off immediately after unplugging.
by
So I pressed Home + Power button and phone stays off and black screen while itunes come from this> (http://tinypic.com/r/14dnkb4/9) state to this state new state (http://tinypic.com/r/30s9cts/9). I can't see any logo or anything on screen as it stays black and off. Also as soon as I stop pressing buttons, the phone goes in DFU mode again. And this whole process of "phone detected in restore mode" start again!!
by
Add a comment
Add your answer
Harris Khan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 5,299
