Mower Blade rubbing deck?
Craftsman garden tractor 26 HP 54" deck blade is rubbing deck evey 30 second for just a second not continues Started last mowing can't find were it rubbing at put white paint on inside of deck but no marks
5 Comments
With no marks, please elaborate on why you think it is rubbing. Sounds like something else to me.
by mayer
Could you please make a quick video?
Adding images to an existing question
by George A.
Have you removed the belt and checked that none of the spindles that the blades are attached to are loose or wobbly? I forgot to put a spacer back on after I sharpened the blades once, and it caused an intermittent shudder because the blade would wobble on the shaft. A worn bearing, or bent spindle shaft could also be an issue to look into.
by Geoff Ice
Thanks but think its the mandrel bearing
by Kevin mac
When I but it under a load the shudder goes from every 4 second to 2 blades are tight mandrel bolts are tight as well unless you think otherwise please let me know signed unsure lol
by Kevin mac
