Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 Long screw damage
Hello!
I changed silent button on iphone 6, then i put display back, turn on phone and start putting esd shield. I put 0,1mm longer screw in down left hole, i heard cracking and when i heard cracking i tako out screw. I put back screen and start testing phone. At one moment screen comming black and turn off completely. I connected phone to itunes, itunes recognized it, but screen is black. Its not backlight problem i saw. I put new display but same again. I force restart it, disconected battery and all that i found on the web.
Any ideas?
1 Comment
What state/country are you in? You will have to sent it to someone who does microsoldering.
by
Add a comment
1 Answer
Chosen Solution
Unfortunately, it sounds like you have Long-Screw Damage. If you want to be certain before sending your logic board out for repair, I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, front camera, rear camera and home button extension flex (see this guide). Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
If you have access to a multimeter, you could measure the battery first. If it reads ~3.8V - 4.2V, then it is good. Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the Home button flex first, then add the rear camera, LCD & Digitizer then from camera flex.
If the bare-bones setup does not get recognized by iTunes, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair. Many shops offer mail-in service and offer a no fix / no fee policy.
Score 3
Add a comment
Add your answer
Aleksandar Lukic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,184
