Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
Problem with touchscreen after glued the frame
Hi everyone!
I have a major problem with the touchscreen on my iphone 5.The display was popped out a little so i tried to glue the frame with superglue.I forget the shield on back of display.Anyway,I did the job ,but i didn't see that it came out to much glue,and after i replaced the display the touchscreen doesn't work and sometimes i get white vertical/horizontal lines.Do you know a solution to remove the glue,or i need to separate the touchscreen from the LCD,and then to buy a new glass?
I have some photos:
Add a comment
A new glass wont help as its just a piece of glass... Try removing the screen and clipping it back together onto the board, if that doesn't work then you need to change the screen.
Over stretching the flex cables at the top of the phone will damage the screen so its probably not the glue its the initial drop it had to cause the screen to lift out (or a swollen battery, pushing the screen out) or caused by pulling the screen to glue it.
Add a comment
Sounds like you damaged the screen when you glued it, id just replace the whole screen for a new one and not bother gluing it, they are so crazy cheap now its not even worth trying to repair.
Add a comment
Add your answer
dragosneagu95 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 355
