Can I run an iMac headless?
I have an early 2009 2.9GHz 24" iMac with an NVIDIA GeForce GT 130 512 MB that is real close to dying. If I can find a replacement, it will cost way too much for this old of an iMac. I'd still like to try and run OS X Server (10.11-max) and know the Mac mini can run headless when configured properly. If I disconnect the graphics card, will the iMac still start up? With it running OS X Server, I can remotely connect to it and use it as a media server or something else.
Thanks
I just ordered a used late 2015 iMac to replace it before it doesn't work anymore. The screen starts fragmenting, gets real fragmented, then locks up.
3 Comments
Try it, if it doesn't boot then there is obviously a problem. Set Automator to make a noise when it starts up and then remove the card and see if you hear the sound after a while.
by Gigabit87898
I might try removing the card and see what happens but I was hoping someone has tried it before.
by plink53
I am running a late 2009 27" iMac with a bad video card. I just unplugged the screen. Control it through screen sharing.
by fxsrider
