Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429 Questions View all
LCD screen flickering on my iMac 2011
imac 21.5 mid 2011
I was instaling SSD drive into my mac and my LCD start flickering since than. I also replaced thermal paste on CPU and graphic card and add some more RAM during this upgrade.
I tried to replace ram and cpu (I have a spare one) led driver board (doesnt help) and v sync cable (was damaged so I order new one- does not help at all). I also try to remove SSD and the problem is still here. On external monitor is everything just fine. I am not able to find any damaged part on my logic board or PSU. Everything else is working ok.
https://youtu.be/SHNyUcMKYNY
What do you think? Do I need a new LCD?
Update (05/04/2017)
New update. When it goes black I am still able to see desktop with flashlight.
Update (05/04/2017)
I perform apple hardware test with my flashlight and it gives me code 4SNS/1/40000001 : VGOR - 10.344
Does anybody knows what does it mean?
Update (05/04/2017)
Another hardware test. Code 4SNS/1/40000001 : VGOR - 10.382
Update (05/05/2017)
New update. LCD completely stops flickering and when I turn on my imac it boots and after a few seconds it restarts itself very quickly and keep restarting again and again so i unplug whole LCD and now it works normally with external monitor. Does this mean my LCD is gone or maybe my power source?
Update (05/05/2017)
Now it is not able to start at all it just spins wents and shuts off.
Score 1
1 Comment:
i think your graphic card is broken men.
by
Add a comment
1 Answer
when it flickers press f3 and it fixes the issue temporary.
3 Comments:
No this not solve the issue.
by
its a graphic issue! you have to find out whats triggering it. mines starts when I google images. then I hit f3 and it goes away. last year I had the issue and I wasn't sure what was causing it, I took it to apple store and they couldn't figure out either so I deleted all the games and apps then it went away for a year...
by
No this is not helping. Imac is not able to start at all now. It looks like cascade issue.
by
Add a comment
Add your answer
Petr Jaroň will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 2,595
