Repair information for the first generation Apple iPad available in Wi-Fi and 3G versions with 16, 32, or 64 GB of storage. Released on April 3rd, 2010. Model numbers: A1219 and A1337.
266 Questions View all
Can I modify an iPad and increase the memory to 128GB?
If I disassemble an iPad, is it possible to replace the internal flash mass memory with a 128GB Samsung SSD 1.8"? what is kind of the iPad's flash mass memory? does the quality of the internal multimedia decrease? Would iTunes support the modified iPad? Would I be able to install the iOS 4.2? Thanx for the answer.
1 Comment
This question was migrated from http://meta.ifixit.com/.
by
Add a comment
1 Answer
Chosen Solution
No. The NAND flash is soldered to the main board, and it does not have an interface that's compatible with an SSD (or space inside for a drive).
It is hypothetically possible to replace the flash chips with larger capacity chips, but that would require a sophisticated surface mount de/soldering setup. In English: a semiconductor company could do it, but probably not an individual.
Score 2
1 Comment:
There is a bunch of equipment on Ebay, for a 150$ which helps u to do it fast and easy. Depend on your will, and manual capabilities. Videos on facebook, and YouTube also. Approximately an hour job
by
Add a comment
Add your answer
Francisco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 10,875
