I get duplicate email on my outlook but not when I web browse
Any one know why you get duplicate mails in outlook but not on your web server viewing via the web browser?
Which version of outlook are you using? What have you done about this far? You night try the Microsoft answer:
This problem may occur if you use the Leave a copy of messages on the server option.
To set the Leave a copy of messages on the server option, follow these steps:
1. On the Tools menu, click E-mail Accounts.
2. Click View or change existing e-mail accounts, and then click Next.
3. Click your POP3 e-mail account, and then click Change.
4. Click More Settings.
5. On the Advanced tab, click to select the Leave a copy of messages on the server check box, and then click OK.
and here is some more
Possible Causes of Duplicate Emails on Outlook Express
Problem: The "Leave Messages on the Server" box has been checked on your Outlook Express account settings.
Fix: Uncheck the "Leave Messages on the Server" box. To do this, click on Tools>Accounts. You will see a box open (named Internet Accounts), click "Mail" tab, click on the mail account, click on Properties>Advanced. Remove the check in the box "Leave a copy of messages on server."
(The following information is from Microsoft Help and Support)
Problem: Outlook Downloads Messages from a POP3 Server Twice Outlook downloads messages from a Post Office Protocol 3 (POP3) server again after it empties the Deleted Items folder even if you have both the Leave a copy of messages on the server and the Remove from server when deleted from Deleted Items options enabled on the POP3 account.
Fix: There is not an available workaround for this problem. . . Simply delete the duplicate messages.
Let us know if this will help....Good Luck
Ok will try this. Use different versions of Outlook...as you said MS does not have a solution yet except delete...
Well we will carry on maybe one day we will have a better answer than delete or reboot!!!!
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 523
2 Comments
This question is off-topic
by rab777hp
does not work?
by paul
