Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Questions View all
Wi-Fi problem: disabled - no hardware - enabled
Hello guys,
I booted up my MacBook Pro as normal and found out my Wi-Fi was turned off. I tried to turn it on but I couldn't. I Googled several software solutions for this problem and none of them worked (power on and off, reset SMC & NVRAM, delete files in preference files in library etc.)
Later Mac OS X started to mention that the Wi-Fi hardware is not connected. Then I thought this might be a hardware issue, because:
- Sometimes my Wi-Fi works and sometimes it doesn't.
- When I opened up the MacBook Pro and reconnected all the cables between the motherboard and the iSight/Bluetooth/Wi-Fi card it sometimes started working again (I tried it multiple times).
- When my Wi-Fi was in fact working it dropped as soon as I hit my laptop on the keyboard with my fist.
Bluetooth never had any problems though. Is it possible that the Bluetooth/Airport cable has separate pathways for Bluetooth and Airport and that only the Airport pathway is broken? Is this possible?
I am thinking that the Bluetooth/Airport cable (the black flat one) is broken.
What do you guys think?
Cheers.
Ezra
1 Comment
Replaced the cable and it solved the problem!
by
Add a comment
1 Answer
Chosen Solution
I would start off with the easiest (and cheapest) to replace which is the Airport and Bluetooth Flex Cable - Apple P/N 922-9750. Otherwise, your Airport board has a problem, while rare it can fail.
Follow this IFIXIT guide: MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Board Replacement
Score 3
1 Comment:
Replaced the cable and solved the problem!
by
Add a comment
Add your answer
Ezra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 173
