High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Questions View all
Touch not working after screen replacement
Replaced the LCD o a customers iPad Pro 12.9, solder job all done well but there's no touch. The LCD comes but but won't respond to my touch. Could it be a bad screen ?
Score 1
Add a comment
Most Helpful Answer
Check to make sure all the connectors are fully inserted. It is possible it is a bad screen but make sure everything is firmly connected and the ports inside are dust free.
Score 1
Add a comment
This problem mostly occur when tech connect LCD with battery connected and filter is blown 120Ohm 450mA near to Touch Connector.
Score 1
Add a comment
Got word that I might have blown the "power touch line" without schematics I don't know what to do :(
Add a comment
If you didn't disconnect the battery while fitting the screen you have burnt out the touch filter unfortunately you need a multimeter and check for continuity
Add a comment
Add your answer
Jesse will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 7
All Time: 2,762
