Repair guides and support for your Samsung TV.
2617 Questions View all
tv will not keep turned on, restarts all the time
As soon as i turn Samsung Television model PS59D6900D tv on in starts going in to a ever lasting restart circle,in turn it on and in seconds in turns off then turns on by its self
1 Comment
@bri29 unplug your set and remove the back. Take some good pictures of all off your boards and post those with your question. In particular your main and power board. that will allow us to see what you see. Use this guide for that
by
Add a comment
Chosen Solution
@bri29, Ross, I am not a TV repairman, Unplug the TV for a couple hours and then reconnect. Did a bit of searching on your issue and possibly bad on board/manual power switch or faulty board/capacitors. See the video links below to perhaps solve your TV's issue. If your TV happens to be under warranty still return for repair/replacement/refund. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=fbcCVv_a...
https://www.youtube.com/watch?v=H0cG3lzj...
http://www.instructables.com/id/Samsung-...
Score 2
Add a comment
See my answer on this here:
There are an estimated 12 million units with this issue, mine included. Class action law suit on it also:
My Samsung smart tv keeps turning on and off
Score 2
Add a comment
I had that problem which was fixed by disabling "Digital text" in the menu options.
Score 1
2 Comments:
problem is that it dont stay on long to get to menu,just got time to pull menu up then turns off
by
Hi, I only had a problem on two channels so picked a working channel before accessing the menu. If you have a working channel, try that one to get into the menu. Hope that helps.
by
Add a comment
Add your answer
ross will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,104
