Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Why does it stop working when I get incoming calls?
When I get an incoming call, sometimes it just reads that the phone stopped working and when I press OK it pops up again and I can't answer the call and have to reset the phone completely. Is it a common problem and if so, does anybody know if and how it can be fixed?
Add a comment
1 Answer
I would recommend connecting to Wi-Fi and make sure that your phone is updated to the latest version of Android OS available. Also check to make sure that your carrier settings are up to date as well. This can sometimes be caused by the Android software trying to use the Phone app and not having something that it needs to continue, so the app fails and shuts down. Hope this helps!
2 Comments:
I tried updating the software but it still happens. Any other suggestions?
by
The only other thing I can suggest is to make sure all your apps are updated, if that doesn't work, try to *first* back up all your data you want to save... then to a factory data reset.
by
Add a comment
Add your answer
Bor Turnšek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 82
