Comprehensive set of repair guides for tablets developed by Amazon, under the name Kindle. Repair is generally pretty easy, and usually only requires screwdrivers and prying tools.
1323 Questions View all
Sound faint. Had snagged headphone cord.
Used headphones to listen to Netflix. Moved and caught the cable. Kindle Fire 7 inch (I believe HD) got knocked down. Able to continue listening but only if the plug was not completely pushed in. Sound ok without being plugged in. UNTIL NOW. All combinations still has a weak sound. Very faint. I thought I had damaged the jack port. If so, can that be replaced? Could the speaker cable just be loose?
Thank you for any input orsuggestions.
Add a comment
1 Answer
Chosen Solution
Hi @maint007 ,
Here is a link to the ifixit guide to repair / replace the headphone socket in a Kindle Fire HD. 1st Generation
This guide also allows access to the speakers if the headphone socket is not the problem.
Couldn't find replacement socket part after a quick search. You might have better luck. Alternatively if you can't find one (if the socket is faulty that is) perhaps this is an option for parts if the price is alright.
Here is a link to the ifixit guide to teardown a Kindle Fire HD. 2nd Generation. Step 12 shows the removal of the headphone socket, available from ifixit
Hopefully this is of some help.
Kindle Fire HD 2013 Image
Guide
Kindle Fire HD 2013 Teardown
Difficulty:
Moderate
Kindle Fire HD Headphone Jack Image
Guide
Kindle Fire HD Headphone Jack Replacement
Difficulty:
Moderate
Score 2
Add a comment
Add your answer
Jeff Pedroley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 89
