The first generation Mazda MX-5, or Miata.
20 Questions View all
miata wil not start with clutch depressed
new battery, all other electrical elements functioning, clutch depressed, starter will not engage.
1 Comment
is there a electrical relay on clutch pedal that controls the start function?
by
Add a comment
1 Answer
Most Helpful Answer
Hi,
There are two clutch switches.
The big white one which is engaged only when the pedal is fully depressed is a starter interlock.
Not sure if this is the same for your year model but hopefully it is of some help.
http://blog.miataracer.com/2012/06/how-t...
There's a smaller one, up under the dash, which disengages when the pedal is slightly depressed. This goes to the cruise control unit as well as to ECU pin 1V. In a M/T car it's a brown-white wire. This wire is also connected to the transmission neutral switch.
Score 3
2 Comments:
thank you...where is the white starter interlock located?
by
Hi @mikemiata ,
It might have changed colour. Is there not one where it is shown in the picture in the link that I posted?
by
Add a comment
Add your answer
michael lutsic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,587
