Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
No Wifi at all and no bluetooth
I had my iPhone for the a few months now, it was a hand me down from my older sister. After a few months of having it, I just woke up the other day and I wasn't able to connect to the WiFi or connect to my bluetooth speakers. But I was able to have 3G available.
I followed all apples steps in trying to restore it but no luck.
Any one can help me. It would totally be awesome.
Thanks
Add a comment
1 Answer
Chosen Solution
Since you tried restoring and the Wi-Fi option is still greyed out and you are unable to turn it on, I believe your Wi-Fi chip most likely failed. This may have been caused by a serious drop.
The Wi-Fi chip will need replacing and that is a job for a microsodlering technician, not a DIYer because it requires a lot of skill and adequate tools and replacement parts.
If the Wi-Fi and Bluetooth are there but the signal is too low then it could be that the antenna broke or came loose. If that's the case, you would need to re-connect or replace the antenna.
Other parts of the Wi-Fi circuit may fail as well, but the above are the most common issues I've faced so far.
Score 3
Add a comment
Add your answer
L I U X X will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,308
