No display image after fall
I dropped my MacBook Pro. It fell half a meter on the top side (it was closed).
- Plugged in to an external monitor works ok
- No light in the apple logo on the back of the display
- Tried to see some image on the display by using a flashlight on the apple logo in the back but couldn´t see anything.
- Webcam works ok
I´m willing to replace the entire display assembly, but I´m unsure if there is another component that might the culprit (like the logic board or some cable). Can you recommend tests to try to isolate the cause?
Thanks!
3 Comments
First things first I would always try disconnecting the Display form the Logic Board and then connecting it back in and make a solid connection. If this doesn't work then I would go with the Display being needed.
by Daniel Mason
You should open up the unit and reseat the display cable, if that doesn't work I would recommend you remove the display, remove clutch cover on display and inspect both ends of LVDS cable. Buying a $400 display on a hunch seems risky.
by Forza Vale
You both were right, reconnecting the LCD cable did the trick. Thank you!
by Fernando Martinez Herrera
