Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
replace battery and sometimes keep restart
I found my iphone5s battery in aida64 details shows only 100mAH, so I replace a battery but still the same, also sometime it keep restarting. what's the problem?
Update (03/26/2017)
I checked may lose filters, don't have microsoldering device around, are there another ways to fix??
1 Comment
When the phone restarts do you know if the charge is close to being 0% or does it happen at a specific charge percentage?
According to the iFixit teardown of the iPhone 5, the iPhone 5s battery should have a capacity of 1440 mAh. Something doesn't seem right.
by
Add a comment
1 Answer
Most Helpful Answer
Check the components near the battery connector, you may have chipped off some like the gas gauge filter (FL11) If so, you have to bring it to a place that does microsoldering that can solder it back on.
Score 3
Add a comment
Add your answer
Yao will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 150
