Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
iPhone 6 Connection Problems please help.
Dear users,
i got 2 probems with my phone,
7 months ago my bluetooth start to failing and every time i connect it to an device , the sound is crunchy like it has a bad connection, also when i hold my hand in the top right corner of the frame, its worse. is there anyway to fix this?
also i recently changed my housing and i used a complete housing,
i have problems with my cell-antenna now. i only get 1 - 2 bars of connection, some times i lose the connection, is it because the dock connector? please help.
regards!
Glenn
2 Comments
Dear amber,
Thanks for replying, but i got problems with my bluetooth, when i connect my phone to any bluetooth device its like it has a bad connection, but my wifi and all is good,
And about the lines so with other words, i cannot use my phone anymore for good cellular connection?
by
Also in my new phone case have the same vertical lines?
by
Add a comment
1 Answer
Most Helpful Answer
The back housing of the iphone 6 has antenna lines that run in it. That is something to look into if your service started acting up after replacement.
For your sound issue, I would try a new headphone jack, I have also had success with opening the phone and using to compressed air to blow any dust or debris off of the circuit board.
Probably wouldn't hurt anything to try a new charging/headphone jack flex cable for the sound and connectivity issues as well.
Score 2
1 Comment:
Dear amber,
by
Add a comment
Add your answer
glennjacobs will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 106
